OSPF dual router solution and configuration
All,
I am looking solution OSPF   both load balance and  primary and backup scenario   design attached
Router and switch : OSPF area 6
router WAN :  OSPF area 0
Router to router cross connect : OSPF area 0
all connected subnet using /30 network
any doucment or tested and proved solution on  similar design  can be great help thank you
Lerner
Design updated
1 ACCEPTED SOLUTION
first to improve your design
summariese from each of the routers from area 6 to area 0 ( use same summary prefix length if you want load balancing )
also you differnt area numbers for each site with switches like one side is 5 and the other is 6 and area 0 in the middle as you did
make sure that the L3 multi homed uplinks see both routers as next hop for the remote subnets when you do show Ip route
to achive this you need to make sure that the cost of the OSPF is identical end to end
Re: OSPF dual router solution and configuration
thank you  , let me put here what I understood
SITE A and SITE B switch SW1-SW4  need to send summarized routes  to the routers  R1 -R4 ,
On the WAN path R1 to R4 , R2 to R3 , R1 - R2 and R3-R4 all should equal cost .
change  one SITE B lan  Area 6 to AREA 5 ??.
It would be great , how to achive  redundancy  like traffic  R2 -R3  primary path & R1 - R4 backup
atached  modified design .
364
