Community Member
OSPF & EIGRP
A connected enrutador 3845 to 2 networks is had, the primary one uses OSPF and we want to implement the secondary one (like backup) with EIGRP. The question is this is possible or is preferable to use static routing.
Blue
Re: OSPF & EIGRP
Why do you want to mix routing protocols? What is the reasoning behind it?
It's normally not a good practice to do so. It makes management and troubleshooting more difficult.
Give us more info and maybe we can give you a better answer.
Victor
Re: OSPF & EIGRP
Hi Luz,
Could you please give us a more detailed description of the topology you have now and the future topology you want to implement as a backup link and/or router.
Istvan
81
