OSPF NBMA Config
Hai,
i wud like to configure ospf in NMBA ...(Frame-Relay) ....My quiestion is Without a Frame-Relay switch is this possible ...is this possible by connecting router back to back ....how can i perform this ....
I want to perform the live cenario in LAB ...Pls help me
Kindly hlp me ...
Thanks in advance ...
Silver
Re: OSPF NBMA Config
Hi There
How many routers do you have available to you.
You can make a Cisco router act as a Frame Switch. I use a 2520 with 4 serial ports as the Frame Switch in my home lab. I run a Frame Relay hub and spoke network with 1 hub router and 3 spoke routers.
If you don't have sufficient routers available, check out Dynamips. You could set up a virtual Frame Relay network using this software.
Best Regards,
Michael
Hai ,
Thanks for the reply ...i have 4 1721 router and one 2800 ...is it possible to make a lab using this ...i ve to check wheather i shud have enough WIC card ....wud be nice if you can pase the Frame-Relay switch config and Hub/Spoke router config ,...
Lijesh.N.C
Hall of Fame Super Bronze
The following document describes how to configure back-to-back Frame Relay.
http://www.internetworkexpert.com/resources/backtoback-framerelay.htm
And, the following document describes how to build a compound high density Frame Relay switch by cascading multiple routers which have a low density of interfaces
http://www.internetworkexpert.com/resources/compound.frame-relay.htm
HTH,
__
Edison.
Hai
Thanks alot Edison .... i think it may take some time for me to arrange this ..setup ..any way i will do this ..thanks a lot onece again
Lijesh.N.C
144
