10-26-2005 10:20 PM - edited 03-03-2019 10:49 AM
GW(config)#router ospf 14
GW(config-router)#neighbor 172.30.0.9
OSPF: Neighbor address does not map to an interface
What does that message mean?
Solved! Go to Solution.
10-28-2005 01:29 AM
How to be in situation when i've more than 2 routers?
Should i create tunnel interface for each pair of routers? Or something else?
10-28-2005 01:50 AM
Yes tunnel for each pair. Much harded to achieve a mesh because of the large number of tunnels you will be creating. If the number is much, then seriously consider using your provider. MPLS VPNs are fully mesh by default. One of their advantages.
