Community Member
OSPF neighbor formed but OSPF authentication configs not correct!
I have a remote router TK and a local router W1. They've formed OSPF neighbor in Area 40, over a T3.
under process 4. But when I checked the config, I found,
1. local router configured with OSPF authentication correctly.
2. Remote router configured with OSPF authentication only on the interface, but not under the area 40
How so??
thanks,
tk#sh ip os 4
Routing Process "ospf 4" with ID 172.16.241.1
tk#sh ip os nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
1xx.1xx.252.200   1   FULL/BDR        00:00:30    1xx.1xx.252.194 GigabitEthernet0/2/0
1xx.1xx.252.201   1   FULL/BDR        00:00:36    1xx.1xx.252.198 GigabitEthernet0/1/0
172.16.240.211    0   FULL/  -        00:00:31    172.16.76.5     Serial2/0
172.16.240.210    0   FULL/  -        00:00:32    172.16.76.1     Serial1/0
The last one is the neighbor in question.
tk#sh run | b r o
router ospf 4
log-adjacency-changes
auto-cost reference-bandwidth 10000
redistribute static subnets
passive-interface GigabitEthernet0/0
passive-interface GigabitEthernet0/1
passive-interface Vlan10
network 1xx.1xx.252.96 0.0.0.15 area 40
network 1xx.1xx.252.192 0.0.0.3 area 40
network 1xx.1xx.252.196 0.0.0.3 area 40
network 1xx.1xx.252.224 0.0.0.15 area 40
network 172.16.76.0 0.0.0.3 area 40
network 172.16.76.4 0.0.0.3 area 40
network 172.16.241.1 0.0.0.0 area 40
tk#sh run int s1/0
Building configuration...
Current configuration : 297 bytes
interface Serial1/0
description Level 3 DS3 - B2154
ip address 172.16.76.2 255.255.255.252
ip ospf authentication message-digest
ip ospf message-digest-key 4 md5 7 15973F03017E720D716218211D054F532E
dsu bandwidth 44210
end
tk#
=======below is from local router
w1#sh ip os 4
Routing Process "ospf 4" with ID 172.16.240.210
router ospf 4
area 0 authentication message-digest
area 40 authentication message-digest
redistribute static subnets route-map NTSB_into_OSPF
redistribute bgp 65000 metric 500 metric-type 1 subnets route-map bgp-forwarded-routes
passive-interface default
no passive-interface Vlan609
no passive-interface Serial1/0/0
no passive-interface Serial1/0/1
no passive-interface Serial1/1/1
no passive-interface Serial2/0/0
no passive-interface Serial4/1/2:0
no passive-interface Serial4/1/4:0
no passive-interface TenGigabitEthernet9/1
no passive-interface TenGigabitEthernet9/2
no passive-interface TenGigabitEthernet9/4
no passive-interface GigabitEthernet10/1
no passive-interface GigabitEthernet10/2
no passive-interface Multilink1
network 1xx.1xx.202.92 0.0.0.3 area 101
network 152.120.255.240 0.0.0.0 area 0
network 152.120.255.242 0.0.0.0 area 0
network 172.16.32.80 0.0.0.15 area 0
network 172.16.32.208 0.0.0.15 area 0
network 172.16.55.144 0.0.0.15 area 0
network 172.16.55.241 0.0.0.0 area 0
network 172.16.60.144 0.0.0.15 area 0
network 172.16.62.0 0.0.0.3 area 0
network 172.16.64.128 0.0.0.3 area 102
network 172.16.67.64 0.0.0.3 area 40
network 172.16.67.68 0.0.0.3 area 40
network 172.16.68.4 0.0.0.3 area 109
network 172.16.68.8 0.0.0.3 area 40
network 172.16.68.12 0.0.0.3 area 101
network 172.16.68.16 0.0.0.7 area 40
network 172.16.68.24 0.0.0.3 area 102
network 172.16.68.120 0.0.0.7 area 40
network 172.16.68.136 0.0.0.7 area 0
network 172.16.240.210 0.0.0.0 area 0
W1#sh run int s1/1/1
description T3 to Tk
ip address 172.16.76.1 255.255.255.252
ip flow ingress
ip pim sparse-mode
dsu bandwidth 44210
framing c-bit
cablelength 10
end
W1#sh ip os nei
172.16.241.1      0   FULL/  -        00:00:34    172.16.76.2     Serial1/1/1
1 ACCEPTED SOLUTION
There is nothing wrong with your configuration. OSPF authentication can be configured either on a per-interface basis or on a per-area basis. If both per-area and per-interface authentication configuration exists, the per-interface configuration is preferred (i.e. the per-interface authentication configuration overrides the per-area config).
In your case, the net effect is that both interconnected interfaces are using the same OSPF authentication mode and the same key, and thus the adjacency forms.
Best regards,
Peter
1 REPLY
Best regards,
Peter
211
