07-15-2006 09:00 AM - edited 03-03-2019 01:20 PM
The OSPF neighbor command permits to create adjacencies with neighbor using unicast instead of the defaul multicast.
I'm juts wondering if it's possible/suggested to create adjacencies with neighbors in different subnets (one or more hops away) on the same stile eBGP does.
Thanks to read
Solved! Go to Solution.
07-15-2006 11:32 AM
Note that OSPF messages are carried in IP headers with a TTL of 1. The only exception is OSPF virtual links as Richard mentioned.
Hope this helps,
07-15-2006 10:17 AM
Stefano
No it is not possible or suggested to try to establish neighbor relationship with routers one or more hops away. EBGP does have a concept of multi-hop neighbors but OSPF does not.
The one exception to wht I have just said is the OSPF concept of virtual links. With virtual link the OSPF router does exchange updates with a router that is multiple hops away.
Rick
07-15-2006 11:32 AM
Hope this helps,
07-15-2006 02:25 PM
you can setup a gre tunnel between routers and put the tunnel network in ospf
for it to work, the tunnel destination on each router must be reachable without ospf.. (ie. static route)
rob nockowitz
ccie #15410
