OSPF on one side it is EXstart and the other side is Full
Looking at the logs Grin router 1 and 2 go to exstart for most neighbours and then fails due to too many retransmits. However Glue routers at the same time go to loading and full. So one end is exstart and the other end is full. I didn't think this was possible.....Can anybody crack this..?
Re: OSPF on one side it is EXstart and the other side is Full
This might be an MTU problem, please review the following document:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0d.shtml
HTH,
Mohammed Mahmoud.
I agree with mohamed, u can try mtu-ignore command and try it. good problem you have posted.
Thanks and Regards,
Srinath
ThankU folks for the response...
I hve cfgured the mtu-ignore and that does not seem to be the problem :-( this is hw the config looks like on the core switch
CONFIGURATION GRIN SIDE
interface Vlan101
description *** MAN_GRIN2GLUEVLAN ***
ip address 192.168.1.8 255.255.255.240
no ip redirects
no ip unreachables
ip ospf message-digest-key 1 md5 7 *******
ip ospf network point-to-multipoint
ip ospf cost 10
ip ospf mtu-ignore
interface Vlan102
description *** MAN_B2GRIN VLAN ***
ip address 192.168.1.33 255.255.255.240
no ip redirects
no ip unreachables
ip ospf cost 10
ip ospf mtu-ignore
router ospf 100
router-id 10.10.255.5
log-adjacency-changes
area 100 authentication message-digest
redistribute static metric 50 subnets route-map FILTER-ROUTES
passive-interface default
no passive-interface Vlan101
no passive-interface Vlan102
network 192.168.5.0 0.0.0.15 area 100
network 192.168.1.32 0.0.0.15 area 100
Hall of Fame Super Bronze
From all the adjacent routers please type the following:
show ip os int bri
show system mtu
show ip os nei
and post the results here.
Did you try to isolate the problem and see if it's authentication related ?
Agree with Edison, and please make sure that both routers don't have the same RID.
HTH,
Mohammed Mahmoud.
if you can run a debug of ospf.
debug ip ospf events
and pass on the o/p it will be of great help.
I suggest to check the port status of the switches as well.
Thanks and Regards,
Srinath.M
Cable&Wireless
As discussed, why would you configure ospf as point to multipoint on metro ethernet? Suggest you change this to barodcast which is default on Ethernet?
Can anyone tell what is the significance of using "ip ospf network point-to-multipoint"..
I dont see any reason to enable the "ip ospf network point-to-multipoint". This will not make any difference on broadcast network.It will make a difference on Frame-relay or ATM PVC's..
-amit singh
"ip ospf network point-to-multipoint" configuration allows you to run OSPF without the need of a DR or BDR.
398
