OSPF over PPPoE
I am working on running OSPF over PPPoE, It works fine with DHCP pool with /24 subnet but with negotiation as client is getting /32 ip address its not working because client and server are at different subnets... so what to do to get it resolve?
regards
Devang Patel
Re: OSPF over PPPoE
u mean u want a client get ip from a dhcp server separated by a router ?
if so
put on the router interface that facing the client the follwoing command
ip dhcp-helper [dhcp server ip addres]
if that not ur requirement post more details
good luck
rate if helpful
Re: OSPF over PPPoE
I already have IP address assign from DHCP... I want OSPF running between Client and Server when server assign /32 ip address to client.
regards
Devang Patel
Re: OSPF over PPPoE
I believe the rule of thiumb is this you cannot adv a /232 from DHCP when the poll is at a /24 net.
Re: OSPF over PPPoE
/32 My mistake
Silver
Re: OSPF over PPPoE
Hi Devang,
There is no workaround to have client get an ip address via PPP negotiation, it must get it via dhcp, so that you can specify the netmask.
As you have mentioned, the ospf adj;s will not form if you assign via PPP since the subnet masks are different.
LR
696
