09-30-2006 04:44 AM - edited 03-03-2019 02:10 PM
Hi All
i use Cisco router together with some
Juniper router. During maintenance time i
use the "set protocol ospf overload" in
Juniper to turn off traffic. It exists a
similar command in Cisco IOS (avoiding tu put a high OSPF cost on each interface) ?
09-30-2006 05:02 AM
Hello, I really dont know anything about Juniper, so could you explain what this command do, and what you are looking for when you implemented it?
Vlad
09-30-2006 05:13 AM
hi vlad,
see you after long time...
here you can have moredetail of this...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/iprrp_r/ip2_s1g.htm
http://www.informit.com/articles/article.asp?p=423772&seqNum=4&rl=1
regards
Devang
09-30-2006 05:11 AM
hi...
To configure the router to signal other routers not to use it as an intermediate hop in their shortest path first (SPF) calculations, use the set-overload-bit command in router configuration mode. To remove the designation, use the no form of this command.
set-overload-bit [on-startup {seconds | wait-for-bgp}] [suppress {[interlevel] [external]}]
please rate this post if it helps
regards
Devang
09-30-2006 06:20 AM
Isnt this used for ISIS?
If what he's looking for is similar to what you've added , then, he's looking for:
max-metric router-lsa
To configure a router that is running the Open Shortest Path First (OSPF) protocol to advertise a maximum metric so that other routers do not prefer the router as an intermediate hop in their shortest path first (SPF) calculations, use the max-metric router-lsa command in router configuration mode. To disable the advertisement of a maximum metric, use the no form of this command.
max-metric router-lsa [on-startup {seconds | wait-for-bgp}]
no max-metric router-lsa [on-startup {seconds | wait-for-bgp}]
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_osph.htm#wp1001316
Vlad
10-01-2006 09:56 AM
more infos for you:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804556e6.html
"Configuring a Graceful Shutdown"
Andrea
