01-03-2007 12:16 AM - edited 03-03-2019 03:13 PM
Hi friends,
My wan routers are showing high cpu utilization and when i checked the show processes cpu, the ospf process is consuming 33% of cpu utilization.What could be the problem
Ravi
01-03-2007 12:42 AM
Is that you have made any changes to the OSPF timers or its all default . Is there any link flapping in your Wan network , which might also spike ur CPU usage on OSPF process.
Hope this helps.
regards
vanesh k
01-03-2007 01:10 AM
Hi Ravi,
can you paste output of "show process cpu" which shows high CPU utilization and "show version" ?
01-03-2007 06:19 AM
"show ip ospf stat" would probably give you a good hint on what is going on.
Hope this helps,
01-04-2007 01:10 AM
01-04-2007 01:19 AM
For a 2600 router with around 3000 routes , CPU utilisation is normal and may anytime increase to 90 . Pls upgrade your router.
regards
vanesh k
01-04-2007 02:08 AM
Hi Vanesh,
Thanks for information, ideally how many routes can with stand a 2600 router, can i have a link which gives me the details to which series of routers can go well with around 3000 routes.
Ravi
01-04-2007 02:28 AM
Hi Ravi,
The number of routes a router handle depends on the memory and its CPU capacity . It would be working fine , but due to some flap and multiple LSA exchanges would make CPU spike .
I dont have a link that explains abt the number of routes each router can handle . If you have a good traffic and if thinking of expansion , you can go for a 2800 or 3800 router and also try to do some summarisation of your external routes.
Hope this helps.
regards
vanesh k
