OSPF Route Injection....
hi all,
I have dought to clarify with you. I have a vlan interface and R1 learend that route from the OSPF. Then I did the area summurization in R1 router 10.74.0.0/19 ( area 0 10.74.0.0 255.255.224.0). Then in R3 I accepted only few routes using a Route Map.My requiment is to allow only selected networks in 10.74.0.0/19  while blocking the others. If I acceppted 10.74.0.0/15 or 10.74.0.0/19 Networks route successfully injected to R3 routing table. But Once I permit 10.74.10.0/23 route is not injected to the R3 routing table.
Do I need to specifically match the exact network (10.74.0.0/19) or How can this happen ?
Everyone's tags (2)
VIP Purple
Harsha,
you have to add an area 0 range command for the specific network you want to allow and advertise it on R1.
area 0 range 10.74.0.0 255.255.224.0
area 0 range 10.74.0.0 255.255.254.0 advertise
This way, 10.74.0.0/23, which is part of the summary, gets advertised.
HTH,
Georg
hi gpuwen,
Thanks for your reply. But I didnt get what you meat. I will explain further.
R1 config :t 0
router ospf 1
R3 config :
router ospf 1
     distribute-list route-map OSPFIN in
ip access-list extended OSPFIN
     permit ip 10.74.10.0 255.255.254.0 any
But no any routes from 10.74.0.0 network display in R3 routing table. Then I change the route map config on R3 as following.
R3 config:
     permit ip 10.74.0.0 255.255.224.0 any
Then all routes to 10.74.0.0 network displayed properly. I want to know why this happened to me.If you want I can rpovide much details.
Re: OSPF Route Injection....
R3 config :
router ospf 1
Remove it!!!
You are not changing route-map config but you are removing an LSA filter built with distribute-list command
Check for reference on Cisco Doc
Alessio
VIP Purple
Harsha,
sorry for the confusion. On R1, you are summarizing:
Yet on R3, you only want to allow:
So, on R1, your OSPF configuration should look like this:
router ospf 1
area 0 range 10.74.10.0 255.255.254.0 advertise
Can you try this and see what the results are ?
Georg
1067
