10-05-2010 05:44 AM - edited 03-04-2019 10:00 AM
topology : R1----R2----R3
- route x.x.x.x is connected on R2 and y.y.y.y on R3 and advertised in ospf through network command...
- sh ip route x.x.x.x or y.y.y.y on R1 reveals that this route has metric 20 and is an intra-area route (so no chances of redistribution)...... whereas the metric should have been 1 (gig-interface).. .......... one other piece of info : the routes are getting redistributed to BGP .......
what is happening ... ?
10-05-2010 06:42 AM
isn't there any bandwidth command used on the lines between R1 and the other routers?
BR,
Milan
10-05-2010 06:50 AM
HI,
Is there cost explicitly specified for sending a packet on an interface of R1 using "ip ospf cost
If so, to reset the path cost to the default value, use the no form of this command.
Pls Rate if Helps !
Best Regards,
Guru Prasad R
10-05-2010 07:30 AM
Hi ,
could you post from R2
show ip ospf interface x/y | i Cost
! where x/y is the interface that has the advertised network
show ip ospf data router R2-router-id
Dan
10-05-2010 07:37 AM
Hello Mukarram,
you haven't provided enough information on this issue
we should see show ip ospf interface on R1, R2, R3 just to see the costs associated to the interfaces
bandwidth command and ip ospf cost at interface level and auto-reference bandwidth at ospf process level can influence the cost of a link.
Hope to help
Giuseppe
10-05-2010 10:04 PM
here are the configs from live network:
interface on which R1 is connected to R2.. the route is 10.171.5.0/24 behind R2
R1#sh ip ospf interface gigabitEthernet 1/0/19
GigabitEthernet1/0/19 is up, line protocol is up (connected)
Internet Address 10.174.101.81/30, Area 4001
Process ID 4001, Router ID 10.159.254.41, Network Type BROADCAST, Cost: 10
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 10.159.254.41, Interface address 10.174.101.81
Backup Designated router (ID) 192.168.255.162, Interface address 10.174.101.82
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:02
Supports Link-local Signaling (LLS)
Cisco NSF helper support enabled
IETF NSF helper support enabled
Index 2/2, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 32
Last flood scan time is 0 msec, maximum is 9 msec
Neighbor Count is 1, Adjacent neighbor count is 1
Adjacent with neighbor 192.168.255.162 (Backup Designated Router)
Suppress hello for 0 neighbor(s)
R1#sh ip route vrf VPN_EDN 10.171.5.0
Routing entry for 10.171.5.0/24
Known via "ospf 4001", distance 110, metric 20, type intra area
Redistributing via bgp 65534
Advertised by bgp 65534 match internal external 1 & 2
Last update from 10.174.101.82 on GigabitEthernet1/0/19, 05:31:15 ago
Routing Descriptor Blocks:
* 10.174.101.82, from 192.168.255.162, 05:31:15 ago, via GigabitEthernet1/0/19
Route metric is 20, traffic share count is 1
route 10.171.5.0 on R2:
R2#sh ip route 10.171.5.0
Known via "connected"
, distance 0, metric 0 (connected, via interface)
* directly connected, via Vlan4
Route metric is 0
10-05-2010 10:15 PM
Also you will need to post from R2:
show ip ospf interface vlan 4
Dan
10-06-2010 01:03 AM
I have created this scenario in LAB and metric 20, intra area occurs under following circumstances.
On R1 if I set ip ospf cost 10 on interface connecting to R2
On R2 if i set ip ospf cost 10 on interface where your IP is configured.
Please find same outpput here
On R2:
R2#interface Loopback99
ip address 10.0.0.2 255.255.255.255
no ip directed-broadcast
ip ospf cost 10
end
R1#
interface FastEthernet1/0/3.21
description --- Connected to R1 ---
encapsulation dot1Q 21
ip address 10.0.3.5 255.255.255.252
ip ospf cost 10
R2#sh ip route 10.0.0.2
Routing entry for 10.0.0.2/32
Known via "connected", distance 0, metric 0 (connected, via interface)
* directly connected, via Loopback99
Route metric is 0, traffic share count is 1
R1#sh ip route 10.0.0.2
Known via "ospf 100", distance 110, metric 20, type intra area
Last update from 10.0.3.6 on FastEthernet1/0/3.21, 00:00:05 ago
* 10.0.3.6, from 10.0.0.2, 00:00:05 ago, via FastEthernet1/0/3.21
So all we need is
show ip ospf interface vlan 4 from R2
Hope this helps
mahesh
10-06-2010 03:19 AM
Hello Mukarram,
it is more clear now.
First the GE routed port between R1 and R2 has cost 10 on R1.
to be noted in OSPF the OSPF cost of the interface that is associated to the IP subnet described in network area command is added to the cost to reach the node
so total cost from R1 is:
ospf cost of R1-R2 link + ospf cost of R2 L3 interface where destination IP subnet is connected
so there is an apparent conflict here because a show ip route 10.171.5.0 on R2 tells you that the route is connected with AD=0 and metric=0
However, R1 uses the OSPF router LSA generated by R2 to calculate total cost to destination and connected protocol on R2 plays no role here.
Clearly as noted by Mahesh also SVI Vlan4 on R2 has OSPF cost 10.
This is also done because a LAN segment is modeled as a star with a cost to enter the shared segment.
Hope to help
Giuseppe
10-07-2010 10:38 PM
thats right, int vlan 4 has cost 10..
