OSPF Routing Problem
1lumkk
My R3 acts as a frame-relay switch connecting R1. The frame-relay circuit is up. However, R1 is unable to see R6 thru ospf routing. Attached here is the config & diagram to explain. Hope some1 can help this novice. Many thanks.
17 Replies 17
Leo Laohoo
Where's your OSPF network statement?
royalblues
Level 10
Level 10
I am not sure i understand what you are trying to achieve
R3 is a FR switch for R1 on one side but which device on the other?. I assume it should be R6 but then the R3 and R6 are connecting via ethernet.
Your frame-relay will be up as the FR switch provides the required clock but doesnt have a FR PVC
Narayan
Ok i understand your topology now.. the Frame circuit PVC is between R1 & R2
The route adv should be R6-eth-R3-eth- R2-FR-R1
With the current config you have a partioned area with Area 3 connecting to area 2 directly and not connecting via backbone area 0
Trying chnaging the fastethernet links between R1 and R3 to area 0 and it should work (or build a virtual-link)
Narayan
Hi Nara,
I had tried to change R1 and R3 to area 0 but it doesn't seem to work. I guess it is something to do with my R3 connectivity to R1 which is a frame-relay. A show ip ospf interface on R3 doesn't seem to list the serial int connecting to R1 as ospf interface. Problem still unresolved.
can you post the configurations of R1 an R3
Narayan
Hello Lum,
have you used ip ospf 1 area 0 on the serial interfaces changing from ip ospf 1 area 2 ?
You may help the router to restart OSPF process on interfaces by shutting and then no shutting the interface to make it to restart.
Hope to help
Giuseppe
But there ISN'T a FastEth link between R1 and R3; there's only a serial link; and the interface on R3 isn't even participating in OSPF.
The problem as I see it is that R3 does not have a single interface assigned to the backbone area. It's got FastEth into Area 3 and another FastEth into Area 2. Its serial interfaces are Layer 2 only. The only backbone ROUTERS are R2 and R1.
So either
a) build a virtual link from R3 area 3 to R2 area 0; or
b) Configure OSPF on R3; make Area 0 point-to-multipoint with R2 and R1 the spokes; make Area 3 point-to-point between R3 and R6.
Seriously, why is R3 only doing L2 switching for Area 0; when its Area 2 and 3 memberships prove to us it's OSPF-capable?
sujitkr7cisco
Dear,
Great, use virtual connnectivity between them and also you can use default route(but not neccessary).
Thanks ,
sujeet
Mohamed Sobair
Level 7
Level 7
The Frame-relay Switch shouldnt participate in the layer-3 routing , here (OSPF), the Functionality of FR-Switch is to provide Connectivity between DTEs at layer-2 based on their DLCIs info.
Inorder for R1 to have reachability to R6 through OSPF routing, then the following has to be applied:
1- Area Must match
2- Stub flag.
3- Hello and Dead Intervals.
Looking at your topolgy, Router 1 and router 6 has to be in the same OSPF area.
Mohamed
Mohamed,
Actually i had the same doubt earlier but the topology is setup like this
The route adv should be R6-eth-R3-eth- R2-FR-R1.. so it is not necessary to have R1 and R6 in the same area.
But as said earlier and reiterated by Guiseppe, the serial connection between R2 and R3 need to be in area 0
Narayan
Mohammed, there is one Layer 2 connection from R2 to R1 (over frame); and a separate L2 connection from R2 to R6 (over FE & via R3).
It seems to me then that since R1 and R6 are both getting into different interfaces on R2, they wouldn't need to be in the same area, right? Wouldn't R2 simply become an ABR between Area 0 (frame interface to R1) and Area 2 (FE interface to R3)? Yes I know this still doesn't get us into Area 3 and R6 but I just want to see if I understand the concepts here.
Mohamed Sobair
Level 7
Level 7
What FE?? the red link should represent a serial interface connectivity, while what was written is FE.
All the topology along with the config needs to be corrected.
Mohamed
The FE link between R2 and R3 (which constitutes Area 2) and the wholly different FE link between R3 and R6 (which constitutes Area 3).
You posted that R1 and R6 need to be in the same area; but this doesn't seem necessary since they aren't on the same Layer 2 link. They come into different interfaces on R2. (R1 comes into R2 on R2's S1/0; R6 would only come in on R2's F0/0.)
Mohamed Sobair
Level 7
Level 7
Ok, I posted that cause I presumed the original poster has made a mistake. Have you checked the Frame-relay Switch config? if so, do you think its valid config? Have you looked at the topology?
Mohamed
