Webcast-Catalyst9k
OSPF & Secondary Address
Hi ,
Is it possible to announce within OSPF the seocndary address on any interface
1 ACCEPTED SOLUTION
Re: OSPF & Secondary Address
if you are trying to form adjacency with the secondary ip address (network) then its not possible to have the adjacency.
regds
Absolutely. As long as you have a network statement covering the secondary address.
One thing to bear in mind though is that IOS will not form an adjacency based on a secondary address.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks a lot.
Kerem
regds
if any, with secondary addresses occur mainly in conjunction with routing protocols, such as OSPF, which cannot establish adjacencies on secondary addresses. Other than that, you can add as many as the software allows you to. I guess the reason why multiple secondary addresses are being used, rather than multiple logical interfaces, is that you do not have to bother with trunking, inter-VLAN routing etc. when using secondary addressing. It is just a simple way of being able to add more hosts. I would be careful, though, to not add to many hosts, since that, and especially with regard to VoIP, can cause problems with delay and dropped packets, which VoIP usually doesn't handle very well.
rate the post if it hleps
regards
Devang
269
