03-31-2014 07:21 AM - edited 03-04-2019 10:41 PM
I appreciate the input, just trying to redistribute routes from OSPF 100 to OSPF 1 in a Nexus 5500, I configured a route-map accordingly but I'm still not seeing any of the routes in a downstream OSPF 1 router, below is the configuration, please let me know if I'm missing something here, thanks again!
ip prefix-list BRAZIL seq 5 permit 120.43.0.0/16 le 32
ip prefix-list BRAZIL seq 6 permit 29.184.0.0/16 le 32
ip prefix-list BRAZIL seq 7 permit 129.0.0.0/8 le 32
ip prefix-list BRAZIL seq 8 permit 18.134.161.0/24 le 32
route-map ospf100-to-ospf1 permit 10
match ip address prefix-list BRAZIL
router ospf 1
router-id 192.168.1.2
redistribute ospf 100 route-map ospf100-to-ospf1
passive-interface default
03-31-2014 07:56 AM
Try adding "subnets" at the end of redistribute command...
BR,
Dragan
03-31-2014 10:11 AM
There is no option to add subnets at the end of the redistribute statement under router OSPF
redistribute ospf 100 route-map ospf100-to-ospf1 ?
<CR>
03-31-2014 10:22 AM
Perhaps you could post the output of show ip ospf on the Nexus?
Also can you verify for us that the routes permitted in the prefix list are in the OSPF data base and learned in process 100?
Rick
03-31-2014 10:26 AM
Thanks Rich, output:
Routing Process 1 with ID 192.168.1.2 VRF default
Stateful High Availability enabled
Graceful-restart is configured
Grace period: 60 state: Inactive
Last graceful restart exit status: None
Supports only single TOS(TOS0) routes
Supports opaque LSA
This router is an autonomous system boundary
Redistributing External Routes from
ospf-100
Administrative distance 110
Reference Bandwidth is 40000 Mbps
SPF throttling delay time of 200.000 msecs,
SPF throttling hold time of 1000.000 msecs,
SPF throttling maximum wait time of 5000.000 msecs
LSA throttling start time of 0.000 msecs,
LSA throttling hold interval of 5000.000 msecs,
LSA throttling maximum wait time of 5000.000 msecs
Minimum LSA arrival 1000.000 msec
LSA group pacing timer 10 secs
Maximum paths to destination 8
Default Passive Interface is enabled
Number of external LSAs 371, checksum sum 0xbe4c3a
Number of opaque AS LSAs 0, checksum sum 0
Number of areas is 1, 1 normal, 0 stub, 0 nssa
Number of active areas is 1, 1 normal, 0 stub, 0 nssa
Area BACKBONE(0.0.0.0)
Area has existed for 4d20h
Interfaces in this area: 15 Active interfaces: 11
Passive interfaces: 15 Loopback interfaces: 1
No authentication available
SPF calculation has run 190 times
Last SPF ran for 0.002239s
Area ranges are
Number of LSAs: 30, checksum sum 0xf2c70
Confirmed that routes are present and learned by OSPF 100
03-31-2014 11:37 AM
Thanks for the additional information. But I am a bit puzzled. I see output that tells me about OSPF 1 but no output about OSPF 100.
Rick
03-31-2014 11:47 AM
Sorry, did not paste, here it is, thanks!
Routing Process 100 with ID 10.100.1.3 VRF default
Supports opaque LSA
Number of external LSAs 152, checksum sum 0x4ee69d
Area (0.0.0.51)
Area has existed for 2w3d
Interfaces in this area: 1 Active interfaces: 1
Passive interfaces: 3 Loopback interfaces: 0
SPF calculation has run 180 times
Last SPF ran for 0.000193s
Area ranges are
Number of LSAs: 4, checksum sum 0x2364f
Routing Process 601 with ID 10.100.112.254 VRF default
Supports opaque LSA
Number of external LSAs 0, checksum sum 0
Number of areas is 0, 0 normal, 0 stub, 0 nssa
Number of active areas is 0, 0 normal, 0 stub, 0 nssa
03-31-2014 01:39 PM
Thanks for the additional information. It is helpful to see the information for OSPF 100. Could you post the output of the OSPF database entries for the LSAs for OSPF 100?
Rick
03-31-2014 03:52 PM
Hi Rich, will do in a few but from a configuration standpoint, is all supposed to be needed for OSPF redistribution in place? these are Nexus 5500 switches, thanks so much!
04-01-2014 06:05 AM
I looked in a config guide for N5500 and did not notice anything that indicates that you are missing any required part of the config. Since I do not know what version of NXOS you are running I can not be sure if the config guide I used matches the version you are running. And since we have not seen the complete config it is difficult to be sure if something is missing. I wonder if it would be helpful to configure a default metric for OSPF 1?
Rick
