10-15-2007 07:15 AM - edited 03-03-2019 07:10 PM
Just wondering if someone can guide me to a document which explains the difference between OSPF and OSPF v2. I am searching the Google currently, but it's not that clear as to what are major differences between the two.
Kindly assisst,
Hassan...
Solved! Go to Solution.
10-15-2007 07:35 AM
Hey Hassan,
Appreciate the question posted by you. Even I didnt knew the differences. In an attempt to answer, I digged thru RFCs to find the difference.
Pls note that Jeff Doyle vol 1 mentions that, v1 (RFC1131) has never gone beyond the experimental stage.
Heres the link for RFC that I had been through:
http://rfc-ref.org/RFC-TEXTS/1247/chapter23.html
I got an opportunity to learn because of you. Unfortunately, I cant rate your question. Sincere Thanks.
10-15-2007 07:35 AM
Hey Hassan,
10-15-2007 07:44 AM
Thanks for the great help. This document was exactly what i was looking for...
Hassan
