Webcast-Catalyst9k
out of band management
Hi Everyone I'm trying to set up an out of band connection to a new router. How do I go about doing that? Does anyone have a config they can share or point me to the right document to do this? Thank you in advance!!
Re: out of band management
The easiest way is to connect a modem to the console port (no configuration required). You need the cable labeled modem that shipped with your router to connect the two.
If I wanted to do it via the Aux 0 port how would I do that? I thought it was:
line aux 0
modem InOut
modem autoconfigure type usr_sportster
transport input all
stopbits 1
speed 9600
I get connected but all I get is a blank screen
Yeah I found those and tried it but no luck
as of yet. Thank you though I may just use
the console port as you suggested.
Building configuration...
Current configuration : 4390 bytes
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
ip domain name yourdomain.com
username test password 0 test123
username cisco password 0 cisco
controller E1 0/0/0
controller E1 0/0/1
controller E1 0/1/0
controller E1 0/1/1
interface Loopback0
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.248
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Async1
ip unnumbered Loopback0
encapsulation ppp
autodetect encapsulation ppp
async mode interactive
peer default ip address pool dialin
ppp authentication pap chap
ip local pool dialin 192.168.10.240 192.168.10.254
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
stopbits 1
line aux 0
password cisco
login local
modem InOut
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
Thanks for the config I will try this out and let you know
570
