11-27-2007 07:47 AM - edited 03-03-2019 07:41 PM
I have high output drops on multilink interface (2xT1). planning to change the hold-queue to 200, wanted to know the impact if any. this is on 2811 router.
11-27-2007 09:03 AM
Hi Jey,
AFAIK, it is not advisible to increase the output queue, as it may leads to TCP timeout triggering retransmission which will congest the interface even more. How about considering QoS?
If you face constant high rate drop in ooutput queue, it is advisible to increase the line rate.
Nagendra
11-27-2007 09:08 AM
qos is also an option..
what do you mean by line rate, upgrade the circuit?
11-27-2007 09:14 AM
Sorry typo. Yes, I mean to increase the line speed (upgrade).
Nagendra
12-05-2007 10:37 AM
Hi Jey!
Do you solved the output queue drops in your circuit? I also have a multilink interface in my company and I'm facing high output queue drop. I have 6Mbps and but I can only reach 4Mbps. My router is a 3640 with QoS. Anyone has any idea of what is causing these output drops. My CPU utilization is a little high (80%).
Thank you.
Regina
12-05-2007 12:32 PM
Hi Regina,
I didn't really solve the problem but it went away once the traffic volume drop back to normal.
