Hello guys i am a little confused :S
my config is like this
class-map match-all class_a
match access-group 197
class-map match-all class_b
match access-group 198
class-map match-all class_c
match access-group 199
policy-map policy_a
class class_c
priority 2048 1024
class class_b
priority 1024 512
class class_a
priority 512 256
class class-default
shape peak 2048000
policy-map policy
class class_c
priority 2048 1024
class class_b
priority 1024 512
class class_a
priority 512 256
class class-default
bandwidth remaining percent 80
random-detect
access-list 197 permit ip aaa.aaa.aaa.aaa 0.0.0.127 any
access-list 197 permit ip any aaa.aaa.aaa.aaa 0.0.0.127
access-list 198 permit ip bbb.bbb.bbb.bbb 0.0.0.255 any
access-list 198 permit ip any bbb.bbb.bbb.0 0.0.0.255
access-list 199 permit tcp any any range aaaaa aaaaa
access-list 199 permit tcp any any eq bbbb
access-list 199 permit tcp any any eq cccc
access-list 199 permit tcp any any eq dddd
access-list 199 permit tcp any any eq eeee
access-list 199 permit tcp any any eq ffff
access-list 199 permit tcp any any eq gggg
access-list 199 permit udp any any range hhhh hhhh
access-list 199 permit udp any any eq iiii
access-list 199 permit udp any any range jjjj jjjj
access-list 199 permit udp any any eq kkkk
i have tested it to 1841 and 2811
i apply to F0/0
service-policy output policy_b
an all works fine, BUT!
i want QoS In and Out of the Router, so, CBWFQ doesnt work as input so i apply it to the internet feed interface in case F0/1, service-output policy_a
when i activate policy_a on F0/1 the router stops respondind to show commands, every show command, BUT i can remove the service-policy from the configuration and when i do that the show commands work as always, i tried only apply to F0/1 but the results was the same... what should i check?
Thanks in advance
