overruns in optical interface with low bandwidth utilization in Cisco 7206VXR
f_baroumas
We have a Cisco 7206VXR and we're experiencing overrun input errors. In most of the documents i have read that these errors can be caused due to the fast rate of the packets that came in the interface. The problem is that the interface is gigabit ethernet with optical fibre and the utilization is approximately 15 Mbps/sec so i believe that oversubscription is difficult to happen.
ach7206PAR1#show interfaces gigabitEthernet 0/3
GigabitEthernet0/3 is up, line protocol is up
  Hardware is BCM1250 Internal MAC, address is 001d.7106.2c19 (bia 001d.7106.2c19)
  Internet address is 10.170.0.18/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 3/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is LX
  output flow-control is XON, input flow-control is XON
  Last input 00:00:50, output 00:00:00, output hang never
  Last clearing of "show interface" counters 16w6d
  Input queue: 0/75/0/182 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 13351000 bits/sec, 1871 packets/sec
  5 minute output rate 4152000 bits/sec, 1480 packets/sec
     13392736499 packets input, 11481619161979 bytes, 0 no buffer
     Received 2 broadcasts, 0 runts, 0 giants, 0 throttles
     7370 input errors, 0 CRC, 0 frame, 7370 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     9652310207 packets output, 2505172836127 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
ach7206PAR1#show ver
Is there possible to have a Layer 1 issue?
5 Replies 5
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Overruns would most likely be caused by a burst of (small) back-to-back packets - i.e. bandwidth utilization doesn't have to be high for this to be problem.
I also see your input queue has registered some flushes, another indication that the router occasionally cannot keep up with an incoming burst of packets.
What NPE are you using?
paolo bevilacqua
Which NPE are you using ?
Cisco 7206VXR (NPE-G1). So what do you suggest to do in order to fix the issue?Increasing the input queue will reduce the errors?The specific circuit is operational for years but yesterday reported a lot of these errors which is strange.
Thanks for your answers.
The error to input ratio is minuscole. It can have been caused by a transient issue, and can be ignored.
thanks
