Webcast-Catalyst9k
P2P 1841 Configuration Question
I have a question that I need some help on. I have two offices in different states. Both routers connect using 256 frame relay. I am using WIC-1DSU-T1-V2 modules in each router. I will put these both on the same subnet so they will see each other. Is there a document to help me configure these routers? Any advice would be helpful.
Thanks in advance.
Silver
Re: P2P 1841 Configuration Question
http://www.cisco.com/en/US/tech/tk713/tk237/tech_configuration_examples_list.html
"Configuring Basic Frame Relay"
"Configuring Point-to-Point Frame Relay Subinterfaces"
about FR:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a0080087d01.html
Hope this helps
Please let me know
Andrea
Thanks, that is what I was looking for.
I needed info on:
Speed for Timeslots (Valid options: 64/56)
Framing (Valid options: esf/sf)
Timeslots (Valid options: 1-24)
Linecode (Valid options: b8zs/ami)
encap frame-relay (Valid options: IETF/CISCO)
frame-relay lmi-type (Valid options:
ansi/CISCO/Q933A)
Silver
http://www.cisco.com/cgi-bin/Support/Cmdlookup/home.pl
for a specific question, please let me know
Andrea
107
