PA-4E1G/120 work as Chanalized E1
Dear Sir,
i want to know if the 7200 module PA-4E1G/120 work as chanalized E1?
i want to know also if that this module is EoS?
what is the Part Number of this module cable?
Silver
Re: PA-4E1G/120 work as Chanalized E1
1.- Yes, it can works as a channelized E1.
2.- No, it isn't, you can buy it.
3.- Here you have the info you need about the cable:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a00800c4bce.html#wp1024733
Hope this helps, if so pls rate the post
Thank you Sir,
i want to know that this module can work for multi site connection to central site (as multi chanel)
122
