03-04-2009 08:29 AM - edited 03-04-2019 03:48 AM
What kind of PA can we use on 7200 to replace the NM-2FE-2W on 3600?
Are there a table that compare PA and NM?
Thank you.
03-04-2009 08:34 AM
There isn't a table comparing PA and NM but you can go to the 7200 Series page and view the supported modules under that chassis:
http://www.cisco.com/en/US/products/hw/routers/ps341/products_relevant_interfaces_and_modules.html
In your case, you need PA-2FE-FX
HTH,
__
Edison.
03-04-2009 08:38 AM
Hi, here is a link for all PA's supported
hxxp://www.cisco.com/en/US/products/hw/modules/ps2033/prod_module_series_home.html
