You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Packet latency on Catalyst L3.
Hello Community,
I have just introduced a L3 switch into my network. this switch does the routing for 4 different subnets via vlans. I have been experiencine lots of packet latency and loss. It is not contstant but every few minutes I see lots of packets ranging from 150ms to 900ms.
I have checked the ports and the txload and the rxload. Below is the output of my command: show interface FastEthernet 0/2
I  have also inserted a picture of my Dell Powerconnect switch that is  hooked up to my Catalyst. Is there something special I should do to  connect the two. I noticed that my catalyst is using Full-Duplex 100Mb/s  and my switch is using a 1000M, but shoudl that 1000M downgrade to  100M? My servers are mostly 100M too.
#show interface fastethernet 0/2
FastEthernet0/2 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0007.0e76.0c84 (bia 0007.0e76.0c84)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 90/255, rxload 40/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:05, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 15735000 bits/sec, 4477 packets/sec
  5 minute output rate 35624000 bits/sec, 3555 packets/sec
     169356269 packets input, 76279088303 bytes, 0 no buffer
     Received 53247 broadcasts (0 multicasts)
     0 watchdog, 36940 multicast, 0 pause input
     132627013 packets output, 160530213511 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
  • WAN Routing and Switching
170
