Packet Per Second Performance of CEF based PBR
Anybody knows where can I get some information regarding
Packet Per Second Performance of CEF based PBR.
VIP Super Bronze
For what platform?
There is no specific platform. I just need the information about it.
In general, can you explain what does it means?
Packet Per Second Performance of CEF based PBR. Thanks
Super Bronze
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What does it mean?  What's the performance, measured in packets-per-seconds, when using both CEF and PBR?
As Reza asked, that would depend on platform unless you were looking for something like "it degrades CEF pps by 11.43%".  Unfortunately, PBR performance impact, if any, is likely to vary per platform and IOS version and also perhaps by actual configuration.  Your question would be similar to what's the packets-per-second performance of CEF and ACLs or CEF and NAT, etc.  Also unfortunately, Cisco doesn't generally document performance of service permutations, because as already noted, it can vary per configuration.
444
