06-21-2007 01:51 PM - edited 03-03-2019 05:32 PM
all my remote sites have a Cisco 2801 router with a T1 wic card connected back to a Cisco 7300 router. If possible, what i would like to do is install a ISND WIC card in the 2801 routers at the remote sites for backup. My question is does Cisco make a wic card or blade for the Cisco 7300 router, so that if the T1s go down at the remote site the router would switch over to the ISDN line. What parts or model numbers would i need to order? Some type of PRI/ISDN card for the 7300 and ISDN WIC card for the 2801 router.
thanks,
06-21-2007 02:21 PM
The 7300 does not support ISDN. You will need and ISR router (smaller again is the 2801) for this.
The BRI card for the 2801 is WIC 1B-S/T-V3.
However the tendency today is to do backup via VPN over ADSL. In this case the card for the 2801 would be WIC-1ADSL, then with an IOS upgrade you can use the onboard VPN encryption module of the 2801.
06-22-2007 09:49 AM
What about the 7200 router, does that support ISDN? Could i get a T1 card for my 7300 router and connect it back via isdn to my remote sites?
thanks,
06-22-2007 12:39 PM
Yes the 7200 has no problem with ISDN. The smaller card is PA-MCX-2TE1.
The 7300 does not support ISDN no matter the card installed. See:
http://cisco.com/en/US/partner/products/hw/routers/ps352/products_data_sheet09186a0080145f58.html
As a recognition to those providing answers, please rate posts using the scrollbox below!
