Community Member
Partitioned Of The Flash
HI
Most ISP Partitioned THE Flach of the core rourer;what is the benefits to do that?
10xs for ur reply
Re: Partitioned Of The Flash
Hi Friend,
By partitioning the flash memory you are creating two logical areas in which data can be stored and accessed by the router. This allows the administrator to write an IOS image to one partition of the flash while a separate image is running in the other partition.
One advantage to this method is that no router downtime is required to upload a new IOS image, whereas using the Flash Load Helper requires a minor amount of router downtime.
HTH, Please rate if it does.
-amit singh
Community Member
Hi 10xs for ur reply!!!
Gold
Following link guides you how to Partitioning Flash Memory works and what are benefits and also how to use Flash Load Helper
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca737.html#wp1001143
M.
Community Member
m.sir!
10xs for ur reply
Community Member
hi
i read the following in ur giving link:""one image acting as a backup for the other. Therefore, if a downloaded image fails to boot for some reason, the earlier running, good image is still available. Each bank is treated as a separate device""
do i need to tell the IOS From where will boot if the the imahe its failed?
10xs
129
