Community Member
Password Recovery for 6524 e 7604Sup32
I have to recovery the login and enable password for a Cisco 6524 and Cisco 7604 with Sup32.
How can I do?
In fact I don't find the recovery procedure for 6524 and for Sup32 on cisco website.
thanks for helping me
antonio
Hall of Fame Super Bronze
Re: Password Recovery for 6524 e 7604Sup32
Community Member
I've just read that document but i don't understand if it is applicable also for 6524 and for a 76k with Supervisor 32.
do you know if the procedure is the same?
antonio
Yes, it's the same.
Community Member
I've noticed some differences for the Cisco 6524 (IOS 12.2(18)ZU2):
1) the "Break sequence" begins when I see this message "Cat6k-MSFC2A platform with 524288 Kbytes of main memory", so after the message "%OIR-6-CONSOLE: Changing console ownership to route processor""
2) the break sequence is "Ctrl+Alt+Break" but I don't know if this break-sequence is due to my tool that is Putty
That's all.
antonio
2027
