Password Recovery in Cisco 4507 catalyst
rite2anil
Hi All, I want to recover the password of catalyst 4507 switch which is connected to a 6509 catalyst and AAA server is active. I tried to change the config register to 0x2141 but again on resetting, it is asking the username for authentication instead of Switch>. Please help me.
Giuseppe Larosa
Hello Anil,
please follow procedure
http://www.cisco.com/en/US/products/hw/switches/ps663/products_password_recovery09186a00800945f7.shtml
you should set config register to 0x2142
Hope to help
Giuseppe
Hi Giuseppe
I am following the same procedure but still not getting the same prompt i.e Switch>. I am attaching the capture text for your ref. Pleasse help.
Hello Anil,
the system is presenting a username/pwd login like it has loaded the configuration.
I see you have two supervisors installed
I would repeat the procedure with only one supervisor inserted
Hope to help
Giuseppe
