password recovery
i have 3845 router,i forget the enable password,so i connected to console &reboot &press CTRL+Break ,after access the setup mode &change the enable password,then exit from setup mode,
i changed the configuration register to the default again 2102,is the configuration file that was in the NVRAM is still present or not
  • WAN Routing and Switching
1 REPLY
Re: password recovery
Yes, the file will still be there. If you have confi register changed back to 2102 from 2142, then it will boot with the saved startup config which is in NVRAM.
HTH, Please rate if it does.
-amit singh
87
