Webcast-Catalyst9k
Pat statico with range
I need to do PAT static but port ranges, the only way I find to do is the following. It does not work when in the pool set up a single ip, if I set an IP range if it works.
This configuration doesn't work
ip nat pool NAME_POOL 10.10.10.100 10.10.10.100 prefix-length 30
ip nat inside source list 101 pool NAME_POOL
access-list 101 permit tcp host 20.20.20.20 range 4000 5000 any
access-list 101 permit udp host 20.20.20.20 range 4000 5000 any
This configuration  work ,  but I can only use a public ip.
ip nat pool NAME_POOL 10.10.10.100 10.10.10.108 prefix-length 38
Can tell me I'm doing wrong. Thank you
125
作成コンテンツを作成するには してください
