Community Member
PAT with puplic ip over ADSL
I have a problem with my 877 Router. A ping to the internet with source Atm 0.1 works. And from the internet to the 80.123.85.105 ip it is also ok.
But from the lan it does´t work.
I think the problem is the PAT config or a route probleme.
Hope you could help me.
thx in advanced
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address 80.123.85.105 255.255.255.248
ip nat outside
ip virtual-reassembly
pvc 8/64
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Vlan1
ip address 192.168.2.254 255.255.255.0
ip nat inside
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password xxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source list 1 interface ATM0.1 overload
access-list 1 permit 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
Silver
Re: PAT with puplic ip over ADSL
Just change the given and then post the results:-
ip nat inside source list 1 interface dialer 0 overload
Add global route with dialer 0 as outgoing interface
ip route 0.0.0.0 0.0.0.0 dialer0
regards
Shivlu Jain
http://www.mplsvpn.info
Community Member
Thx for the answer.
But it was not the solution.
I have the same problem.
Connenction from the router with the source ip from the atm 0.1 is ok.
But not from the lan interface
This is the example from the current config.
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret xxx
no aaa new-model
dot11 syslog
ip source-route
ip cef
username xxx password xxx
archive
log config
  hidekeys
interface ATM0
no ip address
ip nat outside
pvc 8/64
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip nat inside
interface Dialer0
encapsulation ppp
dialer pool 1
dialer-group 1
ip http server
ip nat inside source list 1 interface Dialer0 overload
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
If you do a ping from the router using the LAN address as the source interface, are you still unable to ping?
ping 4.2.2.2 source interface Vlan1
Also if you are able to browse, then it is not a NAT problem.
Community Member
A ping from the source vlan 1 doesn´t work. Only from the ATM 0.1.
I think it is a Nat problem but i dont´t know the solution.
Community Member
Try issuing show ip nat translations. Are there any translations active? I suspect not.
If not try debug ip nat 1 and post some results.
438
