PBR and service policy on the same interface
Hi all,
can I use service-policy input to mark packets with DSCP and then perform PBR based on that DSCP value?
something like this:
class-map DSCP1
match ip access-goup 1
policy-map set_dscp
class DSCP1
set ip dscp af31
interface Ethernet0/0
service-policy input set_dscp
ip policy PBR
route-map PBR permit 10
match ip address 101
set ip nex-hop A.B.C.D
access-list 1 permit 192.168.1.1
access-list 101 permit ip any any dscp af31
I'm not sure if input service-policy is applied first and the PBR or the other way around.
Petr
Re: PBR and service policy on the same interface
Not sure of what IOS version that your router is, but you can take a look at this document on configuring PBR
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a008075fae6.html
I would think that the service-policy would be applied first, then PBR.
hieu
Bronze
hi
why typing two different tools since you are able of achieving you goal by using just route-map, remember with route map you can match traffic and at the same time you can change some packet s parameters , you can code two set one for ip next-hop and the other for dscp at the same time.
give it a try with just route-map and PBR.
256
