PBR command is not supporting on 7606 router.
Siddharam M
Hi All ,
We are planning to configure the ipv6 PBR  on our 7606 routers.  We have configured the route-maps successfully .
but when we tried to apply those on interfaces we are facing an problem .
when we trying to give command # ipv6 policy route-map <route map name> . we are unable to find policy command option in the command list.
IOS Version : c7600rsp72043-advipservicesk9-mz.122-33.SRE3.bin .
can any one pls let me know whether above command is supported or not. attaching the logs
Any quick support is helpful.
Siddharam
pstebner10
Siddharam-
As far as I can tell, you need to upgrade to a v15 IOS to use IPv6 PBR. I don't see it mentioned in the 12.2.33 guide but it is in the v15 guide:
http://www.cisco.com/en/US/docs/routers/7600/ios/15S/configuration/guide/IPv6_PBR.html#wp1064845
HTH,
Paul
I just confirmed in the release notes that you need v15 for this.
pstebner10
Siddharam-
HTH,
Paul
