PBR failover
tarunavakonar
we have 2 internet link and 2 proxy
we configured PBR for 1 link use one proxy
another link use another proxy
but if one link is down then proxy traffic shift to another link visa-versa
plz suggest me the configuration on urgent basis
6 Replies 6
ashok_boin
Level 5
Level 5
If next hop is not reachable which was entered into PBR, then it will route through normal routing table only.
I feel your requirement is already satisified with your existing configuration.
Regards...
-Ashok.
With best regards...
Ashok
what happen we have two public ip pool
internet router connect with firewall on single interface
so we configured one nat on FW(public to private) and one nat on router(public to public)
i have two ACl for different different proxy
pbr configuration is
route-map XX per 10
match ip add 10 (one proxy)
set int se0/0/0
route-map XX per 20
match ip add 10
set int se0/0/1
route-map XX per 30
match ip add 20 (another proxy)
set int se0/0/1
route-map XX per 40
match ip add 20
set int se0/0/0
plz check the config and suggest me
Instead of mentioning the interface, try using the next hop ip address
route-map XX per 10
set ip next-hop
route-map XX per 20
match ip add 20 (one proxy)
set ip next-hop
BTW, are both the public pools from the same ISP?
Narayan
yes both public pool from same isp
no ip in our interface
ip unnumberd of fastethernet
next hop assigned is not possible
no wan ip in link
The above given configuration need to be modified like this to satisfy your requirement.
route-map XX per 10
set int se0/0/0 se0/0/1
route-map XX per 20
set int se0/0/1 se0/0/0
That's it. For first proxy, the primary destination interface used for routing is Se0/0/0 & back up as Se0/0/1 if Se0/0/0 is down. Vice versa for second proxy.
Experiment this & let me know the result.
Please read this document to get more info.
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml#wp14045
Regards...
-Ashok.
Ashok
