PBR Help
i setup policy based routing on my gateway router based on ACL to filter outbound traffic. is it possible to setup a backup default gateway for the PBR so that if the gateway goes down then traffic cen be forwarded to another gateway? how do you configure policy based routing to do that?
1 ACCEPTED SOLUTION
Re: PBR Help
Hi Friend,
You can add another gateway to the ip next command if the gateway is on a directly connected interface
eg.
access-list 1 permit x.x.x.x x.x.x.x.x
route-map PBR permit 10
match ip address 1
set ip next-hop
you can also have a look at recursive PBR if the gateway is not directly connected
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a008021de72.html
HTH, rate if it does
Narayan
1 REPLY
Re: PBR Help
Hi Friend,
eg.
match ip address 1
set ip next-hop
Narayan
120
