PBR on 7600 not implemented in H/W !! ?
Dear all
Would like your assistance plz in verifying why below simple PBR is not implemented in H/W knowing the Copp is not configured
NPE-1#sh ver | i image
System image file is "bootdisk:c7600rsp72043-advipservices-mz.122-33.SRE0a"
NPE-1#sh run int GigabitEthernet1/1
interface GigabitEthernet1/1
ip address 11.0.0.1 255.255.255.0
ip pim sparse-mode
ip policy route-map test  <<-----
ip ospf network point-to-point
load-interval 30
carrier-delay msec 0
mpls ip
mpls traffic-eng tunnels
ip rsvp bandwidth
NPE-1#
NPE-1#sh route-map test
route-map test, permit, sequence 10
  Match clauses:
    ip address (access-lists): 1
  Set clauses:
    ip next-hop 15.0.0.34
  Policy routing matches: 0 packets, 0 bytes
route-map test, permit, sequence 20
  Match clauses:
  Set clauses:
    ip precedence flash
NPE-1#
NPE-1#sh tcam interface GigabitEthernet1/1 acl in ip
* Global Defaults shared
Entries from Bank 0
Entries from Bank 1
    permit      ip any 224.0.0.0 15.255.255.255
    punt        ip any any   <<<<<--------------------------
NPE-1#
NPE-1#sh policy-map control-plane
NPE-1#
Mayn Thanks
Sherif Ismail
Everyone's tags (3)
VIP Super Bronze
Hi Sherif,
When deploying PBR on the 7600, not all actions are hardware based:
The Policy Feature Card (PFC) and any Distributed  Feature Cards (DFCs) provide hardware support for policy-based routing  (PBR) for route-map sequences that use the
match ip address
set ip next-hop
, and
ip default next-hop
PBR keywords.
have a look at this link for more info:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/layer3.html#wp1027016
Thanks Reza for your reply
The problem that I am using options that should be implemented in H/W as "match ip address" & "set ip next-hop"
Waiting for your feedback .. thx
VIP Super Bronze
Sherif,
Not sure about this, but if I am reading the output correctly, only ip any any is being punted to CPU and not your set and match clauses.
Reza
Hi Reza
Actually reason for this is due to route-map sequence 20 which mark all traffic with precedence flash
when route-map was configured only with sequence 10, o/p was as below (as I remember)
Entries from Bank 1
    punt        ip 11.0.0.40 any
    permit      ip any any
NPE-1#
I know a provider who did a swap from 7600 routers to another vendor due to this issue ... he was configuring several PBRs and this caused high CPU utilization due to router S/W processing
BR,
Sherif Ismail
537
