Community Member
PBR on Cisco 3560
I want to route all traffic from 10.20.1.0/24 (Vlan1) to the next hop address 10.0.0.1 (see diagram).
When I try to put the cmd "ip policy route-map pbr_fa0/1" on Vlan1, the cmd is accepted, but does not show up in the configuration. Why? When I test my PBR, it does not work. Thanks in advance.
Community Member
Re: PBR on Cisco 3560
sorry guys I figured out the problem.
I have to enable "sdm perfer routing". Once I did that it worked.
Hall of Fame Super Gold
David
Congratulations on figuring out the solution to your own problem. And thanks for posting back to the forum indicating that you have solved it yourself. It makes the forum more useful when people can read about a problem and can read what was the solution to the problem. You have contributed to that.
Rick
280
