Webcast-Catalyst9k
PBR & PBR Session capacity in 3750, 4500 & 6700
Dear Team,
Can anybody share me the below capacity & performance query on Cisco 3750, 4500 & 6700 Series SWs,
1- how many PBR can support,
2- How many session support / PBR, with the Mem & CPU utilization,
It would be great if somebody give fast repaly on this or shar any kind of documents,
1 REPLY
Re: PBR & PBR Session capacity in 3750, 4500 & 6700
PBR is supported in Hw on those boxes:
3750:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_20_se/configuration/guide/swiprout.html#wp1228588
Also 3750 has the following restriction:
- Doesn't support deny statement in the route-map or in the ACL
- Only set ip next-hop is supported.
4500:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/pbroute.html
Only the set ip next-hop is supported in Hw. Other action will need Software assistance (PBR Flow switching) up to 4096 flows. Beyond flows will be switched in software
6500:
The sup720 supports set ip next-hop, set ip default next-hop, set interface Null 0 and set default interface Null0 in hardware. Other action are supported in software.
Laurent.
223
