Community Member
Pbs NAT cisco 1812 ISR
I have 2 ISP, 2 small d-link router on each ISP (with nat) and 1 cisco 1812. Load-sharing is OK, but i have a pb with NAT to acces from Internet to local server.
Here is my configuration :
version 12.4
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name xxxx.xx
ip name-server xxx.xxx.xxx.xxx
ip ips notify SDEE
interface FastEthernet0
description xxxxxxxxxxxxxx
ip address 12.0.0.250 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address 11.0.0.250 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface BVI1
description xxxxxxxxxxxxxxx
ip address 192.168.0.250 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip classless
ip route 0.0.0.0 0.0.0.0 11.0.0.1
ip route 0.0.0.0 0.0.0.0 12.0.0.1
ip nat inside source route-map NATMAP1 interface FastEthernet0 overload
ip nat inside source route-map NATMAP2 interface FastEthernet1 overload
ip nat inside source static tcp 192.168.0.xxx 3389 interface FastEthernet0 33333
ip nat inside source static tcp 192.168.0.yyy 3389 interface FastEthernet1 33333
no logging trap
no cdp run
route-map NATMAP2 permit 10
match interface FastEthernet1
route-map NATMAP1 permit 10
match interface FastEthernet0
The access from the internet to 192.168.0.yyy is OK, but 192.168.0.xxx is not OK ???
If i change the FE0 to 10.0.0.250, it's OK on .yyy and not on .xxx !!!
At each time, it's only the FE interface with the lower address that is OK !!!
Have you an idea ?
Thanks, and excuse me for my english !!
Gold
Re: Pbs NAT cisco 1812 ISR
I suspect your issue is they way cisco load balances and asymetric routing of your traffic.
Its not this simple but say even addresses alway go out the first path and odd addresses alway go out second.
The nice thing with nat is that it will consitantly pick the same path to a outside machine and therefore always use the same nat address.
You problem is that the outside machine is picking the outside interface to use and the inside machine is using the load balance to pick the path. Just luck if it works. Since you are using 2 differnt NAT addresses to the remote machine you will never get a session open.
If all you have to worry about is 2 machines you can just policy route the traffic back to the proper outside interface to match your nat statements.
I suspect you will also find outbound issues eventually. Many sites use source IP address for security. They get very confused when they think your ip address has changed when they hand off processing to another machine that has a different IP address but is really the same site.
Community Member
OK
Do you think there is a issue ?
OER ?
Gold
Yes there are issues with load balancing and NAT.
Policy routing will fix the sample you gave
296
