PC
Sir,
I have found that my particular PC in LAN is creating a problem either NIC is faulty or PC is infected with virus . Now instead of telling somebody at remote end to remove the PC from Network , I want that PC should be disabled from Router .
I can create ACL in Router which can stop accessing this host from accessing outside. But I want that this PC should remain physically connected to LAN without disturbing other PC.
Can somebody guide ?
regds,
aman
Purple
Re: PC
Hi Aman,
Is this PC connected to a switch ? If so, you could just shut down the switch port that it is connected to.
Hope that helps - pls rate the post if it does.
Paresh
Re: PC
Sir,
I think you are right .. But we do not have manageable switches ....
regds,
aman
Purple
Re: PC
In that case, the best option is to create an ACL on the router LAN interface so that it drops all traffic from that PC. You could do something like the following:
access-list 1 deny host
access-list 1 permit any
interface Ethernet 0
ip access-group 1 in
Paresh
Re: PC
Sir,
I have already tried this .. But that does not seems to work & i have to physically remove the network ..
The same I have observed by configuring ip route-cache flow on ethernet port of router .
when I run show ip cache flow , ouput shows still infected PC
regds,
aman
Purple
Re: PC
That is strange... When you apply the ACL and do a 'sh ip access-lists' command, does it show any matches against the access-list ?
Paresh
Re: PC
Sir,
I have tried by denying one of the PCs and it is showing matches in accesslist for that particular host...
regds,
Aman
Purple
Re: PC
So if it's showing matches for that host, it means that the traffic from that host is getting dropped, right ?
Paresh
Re: PC
Yes Sir...
Thanks . Aman
Purple
Re: PC
I'm a bit confused.. if the traffic is getting dropped, then why do you say that you still see it ?
Re: PC
Sir ,
It is a mistake on my side it was showing in sh ip cache flow.
The reason for the same which I have found is that from the other end , I was running ping to that particular host.
regds,
Aman
Purple
Re: PC
So you can ping the host even if you have an ACL that is supposed to deny all traffic ?
Is there any chance you can post the interface config and the ACL you have configured ?
Paresh
Re: PC
No Sir, I cannot ping the host when it is denied on Router ..
I will send you the config on Monday...
regds
aman
Re: PC
Sir,
Please find the attached config ..
regds,
aman
Purple
Re: PC
Hi Aman,
So when you apply the ACL, you are no longer able to get to that host. Isn't that what you are after ? The output of 'sh ip cache flow' is most likely showing you stats on traffic that was sent before you enable the access-list ....
Paresh.
Re: PC
That's right Sir.
After clear ip cache flow is done , the denied host also disappears.
regds,
aman
Purple
Re: PC
So your problem is solved.
The only entries in 'sh ip cache flow' are for old traffic so the ACL is working well.
Pls do remember to rate the posts if you found them helpful.
Paresh
150
