Per LSP Traffic Rate
pramod
Consider i have multiple LSP paths in an mpls cloud.
How to know the amount of traffic flow / byte switched on per LSP.
Which command is used to view?
Pramod
arun kumar
Hi Pramod,
How the LSP's are built? Is it with LDP, then by default LSP will be built from IP routing table. In this case, its difficult to get traffic flowing a particular LSP because number of LSP's are proportional to the number of routers enabled with MPLS/LDP.
If LSP is built with MPLS TE tunnels, then traffic count can be taken from TE tunnel counters.
HTH...
Arun
yes, u r right LSP's are formed using IGP's table.No TE tunnels. I can see only the bytes switched on P devices.
but not source to destination level, at this level
Hope we have to wait till cisco comes with a new solution !!! :-)
