Per-packet load-sharing on a 7606 router
I have a problem with a 7606 router. I have two link to the same destination ( 2xE3) and I want to use per-packet load-sharing for better usage(the same load) of both links( if I am using per-destination load-sharing the links will have different usage). The problem is that under the interfaces configuration mode I don't have the option for per-packet load sharing. I have only the option for per-destination load-sharing. dCEF is enabled, of course.
Costin.
1 REPLY
Silver
Re: Per-packet load-sharing on a 7606 router
Sadly dont think it is supported on the 7600 platform itself. The only workaround is to multilink the links.
104
