11-06-2006 08:52 AM - edited 03-03-2019 02:36 PM
Can someone suggest a situation where per-packet load balancing would be a better method than per-destination (in CEF)?
11-06-2006 09:01 AM
if you want the load to actually be equal rather than unequal
11-06-2006 09:13 AM
You will use load balancing per packet : 1.When your multiple links are running on 80% average and you cannot make one link to carry 95% and other 65% if done per destination load balancing .
2.When the links are from single provider , you can go for load balancing per packet
Load balancing per destination :
1.If the links are not very much utilised and if per destination load balancing happens also , you will not have problem
2.If your wan links are from multiple providers , so that in case of latency diff from the provider will not have problems in reachability of packets.
Hope it helps
regards
vanesh k
11-06-2006 11:25 AM
Thanks, this does help.
-Shikamarunara
11-06-2006 09:09 AM
Hi Friend,
This can be used if you have 2 parallel links going from Site A to Site B and you want to load-balance the traffic equally on these 2 links. By default the load-balacning will be per-destination and this will not distribute the load equally. Now to achieve the equal distribution of packets on these 2 links use the CEF per-packet load-balancing.
HTH, Please rate if it does.
-amit singh
11-06-2006 11:07 AM
I know how it's used, no this does not answer my question.
My question is; in what kind of situation would it matter to load balance at the packet level as opposed to the destination level?
-Shikamaru
11-06-2006 09:12 AM
Shikamaru
If you have a situation in which out of order packets will not have a negative impact on the applications running and where you want to possibly get more even spread of traffic over multiple paths, then you have a situation in which per packet load balancing might be a better method.
Rick
11-06-2006 09:34 AM
I agree with rick on this. VOIP is one of the example where you cannot run per-packet load-balacning on the parallel links. If you are running VOIP and you enable the per-packet load-balancing, you might turn into a whole lost of problems like voice packet out of order arrival which will make the voice traffic as choppy and un-audible.
HTH,
-amit singh
