Performance Routing Pfr / OER Woes........
Hello again Guy's
Im trying to get PFR working and having a few issues in lab enviroment, I am currently just looking to get a basic PFR fast failover to 192.168.3.0/24, upon which i can build further policies/labs. But alas i am having little luck......
PS The master is also a BR:
Firstly the 2 BGP Routes at the MC:
*> 192.168.3.0      172.31.0.1                           200 4445 4445 i
* i                 192.168.200.2            0    100      0 i
With a secondary static for good measure:
#show run | i ip route
ip route 0.0.0.0 0.0.0.0 192.168.2.250
ip route 192.168.3.0 255.255.255.0 192.168.2.253 255 name TestSecondaryRoutePFR
#show pfr master
OER state: ENABLED and ACTIVE
  Conn Status: SUCCESS, PORT: 3949
  Version: 3.0
  Number of Border routers: 2
  Number of Exits: 2
  Number of monitored prefixes: 0 (max 1000)
  Max prefixes: total 1000 learn 2500
  Prefix count: total 0, learn 0, cfg 0
  PBR Requirements met
  Nbar Status: Inactive
Border           Status   UP/DOWN             AuthFail  Version
192.168.2.254    ACTIVE   UP       00:01:44          0  3.0
192.168.2.253    ACTIVE   UP       00:01:44          0  3.0
Global Settings:
  max-range-utilization percent 20 recv 0
  mode route metric bgp local-pref 5000
  mode route metric static tag 5000
  mode route protocol pbr
  trace probe delay 1000
  logging
  exit holddown time 60 secs, time remaining 0
Default Policy Settings:
  backoff 180 360 180
  delay relative 50
  holddown 90
  periodic 90
  probe frequency 56
  number of jitter probe packets 100
  mode route control
  mode monitor both
  mode select-exit best
  loss relative 10
  jitter threshold 20
  mos threshold 3.60 percent 30
  unreachable relative 50
  resolve delay priority 11 variance 20
  resolve range priority 12 variance 0
  resolve utilization priority 13 variance 20
Learn Settings:
  current state : STARTED
  time remaining in current state : 107 seconds
  throughput
  delay
  no inside bgp
  traffic-class filter access-list DENY_GLOBAL_LEARN_LIST
  monitor-period 1
  periodic-interval 0
  aggregation-type prefix-length 24
  prefixes 100 appls 100
  expire after time 30
  Learn-List seq 20 refname Learn_List_Remote1_Prefix
    Configuration:
     Traffic-Class Prefix-list: Remote1_Subnets
     Aggregation-type: prefix-length 24
     Learn type: throughput
     Session count: 50 Max count: 100
     Status: INACTIVE
    Stats:
     Traffic-Class Count: 0
#show pfr master active-probes
        OER Master Controller active-probes
Border   = Border Router running this Probe
State    = Un/Assigned to a Prefix
Prefix   = Probe is assigned to this Prefix
Type     = Probe Type
Target   = Target Address
TPort    = Target Port
How      = Was the probe Learned or Configured
N - Not applicable
The following Probes exist:
State      Prefix             Type     Target          TPort   How     Codec
Unassigned                    echo     192.168.3.254       N  Cfgd         N <-- ?
The following Probes are running:
Border          State    Prefix             Type     Target          TPort
Nothing.......?
Config on MC:
pfr master
policy-rules Remote_1_General
logging
border 192.168.2.254 key-chain prf
  interface FastEthernet0/1 internal
  interface FastEthernet0/0.100 external
   max-xmit-utilization percentage 80
   link-group MPLS
border 192.168.2.253 key-chain prf
  interface Tunnel0 external
   link-group DMVPN
learn
  throughput
  delay
  periodic-interval 0
  monitor-period 1
  list seq 20 refname Learn_List_Remote1_Prefix
   traffic-class prefix-list Remote1_Subnets
   throughput
max prefix total 1000
holddown 90
backoff 180 360
mode route control
periodic 90
active-probe echo 192.168.3.254
pfr border
logging
local FastEthernet0/1
master 192.168.2.254 key-chain prf
pfr-map Remote_1_General 100
match pfr learn list Remote1_Subnets
set periodic 90
set mode route control
set mode monitor fast
set resolve utilization priority 2 variance 10
no set resolve range
set unreachable threshold 100000
set active-probe echo 192.168.3.254
set probe frequency 4
Prefix list: ip prefix-list Remote1_Subnets seq 5 permit 192.168.3.0/24
Any Help would be much appriceated as always.
Regards Neil
Regards Neil http://uk.linkedin.com/pub/neil-grant/20/5b0/267
Everyone's tags (5)
1 REPLY
You have defined a learn-list called "Learn_List_Remote1_Prefix" in your learning section.
But in your pfr-map you reference the access-list instead of the learn-list. If you plan to use the automatic learning, then you have to use the learn-list name in your pfr map, ie:
match pfr learn list Learn_List_Remote1_Prefix
Cheers.
/jmb
989
