Performance Solution
Amin Shaikh
I have a Server with Two NIC.
One of the NIC of the Server is connected to 4500 Ethernet Module.
To improve the performance of the Server I would like connect the second NIC.
What is the best possible solution/configuration?
royalblues
Level 10
Level 10
Friend,
You can configure etherchannel between the server and the switch by connecting another cable between the two.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a008014edfa.shtml
you can also configure teaming with the 2 NICs
http://h18006.www1.hp.com/products/servers/management/rdp/knowledgebase/00000108.html
HTH, rate if it does
Narayan
Thanks.
Using Etherchannel option what configuration is required on the Server Two nic.
Will there be Two IP address assigned on the server. { One IP for each interface }
some of my applications are hardcoded IP address.
