Webcast-Catalyst9k
PfR on ASR1001.
Hello at all.
We are using two ASR1001 with IOS-XE version 15.1(3)S2 and IP base license to connect to two different ISP.
We want to configure PfR on these routers. Can someone suggest new IOS version, feature set and license?
Many thanks.
Regards.
Andrea
PfR on ASR1001.
Andrea-
IP Base should work fine. You will want to upgrade to IOS-XE 3.3 so one of your routers can be the Master Controller.
Hope it helps.
PfR on ASR1001.
Hi Adrea,
I agree with Collin. you can go for higher release(IOS XE-3.4s or 3.5s) whcih has support for additional features like target discovery,netflow export v9 format etc
http://www.cisco.com/en/US/docs/ios/ios_xe/3/release/notes/asr1k_feats_important_notes_35s.htmlhttp://www.cisco.com/en/US/docs/ios-xml/ios/pfr/command/pfr-cr-book.html
Sathvik K V
PfR on ASR1001.
Hello and many thanks for your help.
Actual system image file is "asr1001-universalk9.03.04.02.S.151-3.S2.bin". So if I understand well, ASR is running 3.4.2S,
Where am I doing wrong!?
Regards.
Andrea
PfR on ASR1001.
Andrea,
Correct, Hope the below mentioned URL helps
http://www.cisco.com/en/US/docs/routers/asr1000/release/notes/asr1k_rn_intro.html
Sathvik K V
PfR on ASR1001.
Yes, this document helps.
But if ASR runs 3.4, why I'm not able to configure PfR?
Regards.
Andrea
PfR on ASR1001.
Do you mean   not able to see  any commands related to PFR on the device!!
Sathvik K V
PfR on ASR1001.
Yes. I'm not able to see any commands!
Regards.
Andrea
PfR on ASR1001.
Can you paste the results of  p? from config mode?
PfR on ASR1001.
Sure!
gw-1(config)#p?
parser      password     platform          policy-manager
policy-map  policy-peer  port-channel      ppp
privilege   process      process-max-time  prompt
gw-1(config)#
Re: PfR on ASR1001.
About PfR from DOCWIKI....
What are the Software Image requirements for Cisco Performance Routing (PfR) on the ASR1k?
ASR1001: Use Universal Image (U or UK9) with Advanced IP Services (AIS) or Advanced Enterprise Services (AES) technology package license
PfR on ASR1001.
Andrea,
Will have a look on ehy PFR commands are not available, meanwhile if you are keen on implementing PFR would suggest to use 3.9s which i feel is a much stable version for PFR.
Sathvik K V
Re: PfR on ASR1001.
Many thanks for your suggestion. At the end, we need to upgrade software to 3.9 and license to AIS or AES.
Regards.
Andrea
Re: PfR on ASR1001.
Thats correct. Other version less that 3.9 also support but i recommened 3.9. If you have a lab can try with some lower versions
Why 3.4s isnt supporting remains as a puzzle!!
Sathvik
Re: PfR on ASR1001.
So that's where it is hiding, in the docwiki. I looked everywhere in CCO and jumped into every ASR I could find. All had the pfr commands. Sorry about that.
Re: PfR on ASR1001.
May be you are using an AIS or an AES technology package license.
Many thanks for your help.
Regards.
Andrea
Re: PfR on ASR1001.
Collin & Andrea,
This may be of some help when we talk abot the IOS to be used. Scroll down to the question
What are the Software Image requirements for Cisco Performance Routing (PfR) on the ASR1k What are the Software Image requirements for Cisco Performance Routing (PfR) on the ASR1k?
http://docwiki.cisco.com/wiki/Performance_Routing_FAQs
Sathvik
1233
