10-30-2013 04:31 AM - edited 03-04-2019 09:27 PM
Hello Everybody,
I´have set a Lab with
2 Routers, one is the MC/BR and the second is the second Border.
Here is the configuration ont MC/BR
MC_BR#sh pfr master
OER state: ENABLED and ACTIVE
Conn Status: SUCCESS, PORT: 3949
Version: 3.0
Number of Border routers: 2
Number of Exits: 3
Number of monitored prefixes: 46 (max 5000)
Max prefixes: total 5000 learn 2500
Prefix count: total 46, learn 30, cfg 0
PBR Requirements met
Nbar Status: Active
Border Status UP/DOWN AuthFail Version
1.1.1.1 ACTIVE UP 00:19:05 0 3.0
10.10.10.2 ACTIVE UP 00:19:04 0 3.0
Global Settings:
max-range-utilization percent 20 recv 0
mode route metric bgp local-pref 5000
mode route metric static tag 5000
trace probe delay 1000
no logging
exit holddown time 60 secs, time remaining 0
Default Policy Settings:
backoff 300 3000 300
delay threshold 250
holddown 300
periodic 0
probe frequency 56
number of jitter probe packets 100
mode route control
mode monitor fast
mode select-exit best
loss threshold 3
jitter threshold 20
mos threshold 3.60 percent 30
unreachable threshold 3
resolve delay priority 11 variance 20
Learn Settings:
current state : STARTED
time remaining in current state : 102 seconds
throughput
no delay
no inside bgp
monitor-period 1
periodic-interval 0
aggregation-type prefix-length 24
prefixes 10 appls 10
expire after time 720
Learn-List seq 5 refname learning_APP
Configuration:
Traffic-Class Application: http httpssl dns
Aggregation-type: prefix-length 24
Learn type: throughput
Session count: 1000 Max count: 1000
Policies assigned: 10
Status: ACTIVE
Stats:
Traffic-Class Count: 17
Learn-List seq 6 refname learning_Mangement
Configuration:
Traffic-Class Application: icmp telnet
Policies assigned: 11
Status: ACTIVE
Stats:
AS you can see on the configuration , i have used an automtatical Learn for Application, as the Border are connecting to the ISP or Internet , i don´t have BGP, i just use a static defautlt route with a parent route pointed to the ISP.
So i can´t configure a specific prefix for the ISP because i don´t know all the prefix people surf on the internet ? so i let automatic learn
It appear that the PFR can´t optmized the application traffic learning automatically with this error :
*Oct 30 11:53:43.957: %OER_MC-5-NOTICE: Uncontrol Appl Prefix 93.184.219.0/24 http, Exclude prefix failed so uncontrol traffic
MC_BR(config)#pfr mas
MC_BR(config)#pfr master
*Oct 30 11:53:44.169: %OER_MC-5-NOTICE: Uncontrol Appl Prefix 173.194.41.0/24 httpssl, Exclude prefix failed so uncontrol traffic
*Oct 30 11:53:44.181: %OER_MC-5-NOTICE: Uncontrol Appl Prefix 184.170.128.0/24 http, Exclude prefix failed so uncontrol traffic
*Oct 30 11:53:44.661: %OER_MC-5-NOTICE: Uncontrol Appl Prefix 80.94.76.0/24 http, Exclude prefix failed so uncontrol traffic
So i don´t know how can i solve this problem ? and what is the meaning of this log
Here is the Policy that i have :
delay threshold 250
holddown 300
periodic 0
probe frequency 56
mode route control
mode monitor fast
loss threshold 3
jitter threshold 20
oer-map QOS1 10
sequence no. 8444249301975040, provider id 1, provider priority 30
host priority 0, policy priority 10, Session id 0
match oer learn list learning_APP
delay threshold 250
holddown 300
periodic 0
*probe frequency 4
mode route control
*mode monitor fast
loss threshold 3
jitter threshold 20
next-hop not set
forwarding interface not set
Forced Assigned Target List:
active-probe echo 4.2.2.2 target-port 0
oer-map QOS1 11
sequence no. 8444249302040576, provider id 1, provider priority 30
host priority 0, policy priority 11, Session id 0
match oer learn list learning_Mangement
delay threshold 250
holddown 300
periodic 0
probe frequency 56
mode route control
mode monitor fast
loss threshold 3
jitter threshold 20
next-hop not set
* Overrides Default Policy Setting
MC_BR#
THANK U IN ADVANCE
10-30-2013 07:05 AM
Hi Junior,
Try using mode monitor active or both.
Sathvik K V
11-01-2013 02:24 AM
Here is the config on the MC/BR and the BR
MC/BR
hostname MC_BR
boot-start-marker
boot-end-marker
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
dot11 syslog
flow record MYRECORD
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect ipv4 dscp
collect interface output
collect counter bytes
collect counter packets
flow monitor MYMONITOR
record MYRECORD
ip source-route
ip cef
no ip domain lookup
key chain pfr
key 0
key-string cisco
pfr master
policy-rules QOS
logging
border 1.1.1.1 key-chain pfr
interface FastEthernet0/0 external
link-group isp_primary
interface FastEthernet0/1 internal
border 10.10.10.2 key-chain pfr
link-group isp-secondary
interface Vlan200 external
learn
throughput
periodic-interval 0
monitor-period 1
prefixes 10 applications 10
list seq 5 refname learning_APP
traffic-class application nbar http secure-http dns
throughput
list seq 6 refname learning_management
traffic-class application nbar icmp telnet ssh
delay threshold 250
loss threshold 3
mode route control
mode monitor active
no resolve delay
no resolve range
no resolve utilization
pfr border
local Loopback1
master 1.1.1.1 key-chain pfr
license udi pid CISCO2811 sn FCZ120570ZV
username cisco password 0 cisco
redundancy
track 10 ip sla 10 reachability
class-map match-any medium
match protocol icmp
match protocol telnet
class-map match-any WEB
match protocol http
match protocol secure-http
match protocol dns
policy-map Marking
class WEB
set ip dscp cs2
class medium
set dscp cs1
interface Loopback0
no ip address
interface Loopback1
ip address 1.1.1.1 255.255.255.255
description ISP 1 ( EXTERNAL)
bandwidth 56
ip address 212.96.23.178 255.255.255.252
ip nat outside
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
description LAN ( INTERNAL )
ip address 10.10.10.1 255.255.255.0
ip flow monitor MYMONITOR input
ip nat inside
standby 0 timers 2 4
standby 10 ip 10.10.10.50
standby 10 priority 150
standby 10 preempt
standby 10 name HSRPGRPE1
standby 10 track 10 decrement 100
duplex auto
speed auto
service-policy input Marking
router bgp 10
bgp router-id 1.1.1.1
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
redistribute static
neighbor 10.10.10.2 remote-as 10
neighbor 10.10.10.2 update-source FastEthernet0/1
neighbor 10.10.10.2 next-hop-self
default-information originate
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.10.10.201 21 212.96.23.178 21 redundancy HSRPGRPE1 extendable
ip route 0.0.0.0 0.0.0.0 212.96.23.177 track 10
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 200
ip access-list extended CS1_Medium
permit ip any any dscp cs1
ip access-list extended CS2_WEB
permit ip 10.10.10.0 0.0.0.255 any dscp cs2
ip access-list extended QOS
permit tcp any any eq www
permit icmp any any
permit tcp any any eq 443
permit tcp any any eq domain
ip prefix-list BORDER seq 2 permit 105.174.0.0/24
ip sla 10
icmp-echo 212.96.23.177
threshold 500
timeout 500
frequency 3
ip sla schedule 10 life forever start-time now
access-list 10 permit 10.10.10.0 0.0.0.255
route-map test permit 10
pfr-map QOS 10
match pfr learn list learning_APP
set delay threshold 250
set mode monitor fast
set active-probe echo 4.2.2.2
set probe frequency 2
pfr-map QOS 11
match pfr learn list learning_management
control-plane
alias exec flow sh flow monitor MYMONITOR cache format tabl
banner motd ^C **** WELCOM TO MASTER CONTROLLER ****
banner motd ^C
line con 0
password cisco
logging synchronous
login local
line aux 0
line vty 0 4
password cisco
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
end
Here is the config on th BR
hostname BORDER1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
match ipv4 protocol
collect ipv4 dscp
record MYRECORD
ip source-route
ip cef
no ip domain lookup
key chain pfr
key 0
key-string cisco
pfr border
local FastEthernet0/1
license udi pid CISCO2811 sn FCZ132671UR
redundancy
interface Loopback1
ip address 2.2.2.2 255.255.255.255
bandwidth 5000
ip address 105.174.0.10 255.255.255.252
ip nat outside
load-interval 30
duplex auto
speed auto
ip address 10.10.10.2 255.255.255.0
ip nat inside
standby 10 preempt
duplex auto
speed auto
interface FastEthernet0/1/0
switchport access vlan 200
no ip address
load-interval 30
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
no ip address
interface Vlan1
no ip address
interface Vlan200
bandwidth 1000
ip address 105.168.0.2 255.255.255.252
router rip
version 2
network 10.0.0.0
network 105.0.0.0
no auto-summary
router bgp 10
bgp router-id 2.2.2.2
network 2.2.2.2 mask 255.255.255.255
redistribute static
neighbor 10.10.10.1 remote-as 10
neighbor 10.10.10.1 update-source FastEthernet0/1
neighbor 10.10.10.1 next-hop-self
no ip http server
ip nat inside source static tcp 10.10.10.201 21 105.174.0.10 21 redundancy HSRPGRPE1 extendable
ip route 0.0.0.0 0.0.0.0 105.174.0.9 name UNITEL
ip route 0.0.0.0 0.0.0.0 105.168.0.1 200 name ISP2
ip sla 10
icmp-echo 105.174.0.9
threshold 500
timeout 500
frequency 3
control-plane
line con 0
password cisco
logging synchronous
login local
line aux 0
line vty 0 4
password cisco
logging synchronous
login local
transport input all
end
Here is the Sho command for sh pfr master policy, sh pfr master learn list and sh pfr master
MC_BR#sh pfr master
Version: 3.0
Number of Exits: 3
Number of monitored prefixes: 19 (max 5000)
Prefix count: total 19, learn 19, cfg 0
Nbar Status: Active
1.1.1.1 ACTIVE UP 00:07:09 0 3.0
10.10.10.2 ACTIVE UP 00:07:09 0 3.0
Global Settings:
logging
delay threshold 250
holddown 300
periodic 0
probe frequency 56
mode route control
mode monitor active
loss threshold 3
jitter threshold 20
Learn Settings:
time remaining in current state : 87 seconds
throughput
no delay
no inside bgp
monitor-period 1
periodic-interval 0
Configuration:
Traffic-Class Application: http secure-http dns
Status: ACTIVE
Stats:
Traffic-Class Count: 6
Learn-List seq 6 refname learning_management
Configuration:
Traffic-Class Application: icmp telnet ssh
Learn type:
Status: ACTIVE
Stats:
Traffic-Class Count: 0
MC_BR# sh pfr master policy
delay threshold 250
holddown 300
periodic 0
probe frequency 56
mode route control
mode monitor active
loss threshold 3
jitter threshold 20
oer-map QOS 10
*delay threshold 250
holddown 300
periodic 0
*probe frequency 2
mode route control
*mode monitor fast
loss threshold 3
jitter threshold 20
next-hop not set
oer-map QOS 11
match oer learn list learning_management
delay threshold 250
holddown 300
periodic 0
probe frequency 56
mode route control
mode monitor active
loss threshold 3
jitter threshold 20
next-hop not set
pfr-map QOS 10
pfr-map QOS 11
learn
throughput
periodic-interval 0
monitor-period 1
throughput
delay threshold 250
loss threshold 3
mode route control
mode monitor active
no resolve delay
no resolve range
