01-28-2014 01:36 AM - edited 03-04-2019 10:10 PM
Hi All,
Is it possible to have two DRs in a LAN? I have a L2 switch connected to a router which is elected as a DR, the streamers are connected to the same Switch. i need to connect another router to the same L2 switch and distribute the stream to another network.
When i added the other router, it looks like it is not receiving the multicast because the first router is elected as a DR.
Anas
01-28-2014 04:29 AM
Anas,
There was a load balancing pim rfc out there that addressed this type of issue. The rfc expired in 2013, but I can't find a replacement. According to http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6552/ps6592/whitepaper_c11-474791.html, under Alternating DR Priority, Cisco recommends that you put a DR on a separate vlan in order to support the same streams. They do state in the document that 50% of the users would still notice an outage, so I'm going to assume based on this document that there's not a way of having to DRs on the same lan.
Here's the RFC I was speaking about:
http://tools.ietf.org/html/draft-ietf-pim-drlb-02
HTH,
John
*** Please rate all useful posts ***
01-28-2014 04:42 AM
Anas,
John is correct. If you have more than one DR on a segment, one will be elected the DR (I believe this is based upon highest IP address) could be wrong though.. Nevertheless, that's what's causing your specific issue. I would look linto load balancing like John suggested.
01-28-2014 05:45 AM
Anas
Perhaps i am misunderstanding but the PIM DR is simply the router that is responsible for IGMP queries within the LAN segment. If you add another router and it is not elected DR that should not stop the router receiving the multicast stream. The new router simply registers with the DR that it wants to to receive that stream and then it can route the multicast stream to the remote network.
Of course you need something on the remote network to request the stream so the new router knows it needs to register for the stream.
Jon
01-28-2014 06:44 AM
Hi All,
Thank you for your feedback..
Actually i want to build two separate multicast trees from the same L2 switch. the first one is already up and working fine. but i am facing issue with the new router (R1) that is connected to the same L2 switch.
The design is as below:
Streamers
(L2 SW)
R1 Rx Old Router
| LAN/Receivers
WAN
R2
(Receivers)
Below is the configs of the R1 and R2:
I tried also to filter the PIM neighbor between R1 and Rx. now R1 is DR, but still the stream doesnot work from R1 down to the LAN of R2
R2:
ip vrf IPTV
ip multicast-routing vrf IPTV
vlan 301
name IPTV-WAN
vlan 302
name IPTV-Site2
interface GigabitEthernet0/24
description WAN
switchport trunk allowed vlan 1,100,200,250,301,2011,2012
switchport mode trunk
interface Vlan301
ip vrf forwarding IPTV-WAN
ip address 10.51.3.29 255.255.255.240
ip pim sparse-mode
standby 101 ip 10.51.3.30
standby 101 priority 110
standby 101 preempt
interface Vlan302
ip address 10.51.4.2 255.255.255.0
ip pim sparse-mode
standby 102 ip 10.51.4.1
standby 102 priority 110
standby 102 preempt
ip igmp join-group 239.3.3.3
ip igmp join-group 239.1.1.141
ip pim vrf IPTV rp-address 10.51.5.5
ip pim vrf IPTV spt-threshold infinity
ip route vrf IPTV 10.51.5.5 255.255.255.255 10.51.3.17
R2#sh ip mroute vrf IPTV
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group,
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.1.1.141), 01:10:21/00:02:32, RP 10.51.5.5, flags: SCL
Incoming interface: Vlan301, RPF nbr 10.51.3.17
Outgoing interface list:
Vlan302, Forward/Sparse, 01:10:21/00:02:32
(*, 239.1.1.102), 01:09:22/00:02:31, RP 10.51.5.5, flags: SC
Vlan302, Forward/Sparse, 01:09:22/00:02:31
(*, 239.255.255.250), 01:09:20/00:02:39, RP 10.51.5.5, flags: SC
Vlan302, Forward/Sparse, 01:09:20/00:02:39
(*, 239.3.3.3), 01:10:21/00:02:37, RP 10.51.5.5, flags: SCL
Vlan302, Forward/Sparse, 01:10:21/00:02:37
(*, 224.0.1.40), 01:10:21/00:02:39, RP 10.51.5.5, flags: SCL
Vlan302, Forward/Sparse, 01:10:21/00:02:39
R2#sh ip pim vrf IPTV rp mapping
PIM Group-to-RP Mappings
Group(s): 224.0.0.0/4, Static
RP: 10.51.5.5 (?)
R1:
ip vrf IPTV
vlan 301
name WAN-IPTV
vlan 302
name LAN-IPTV
interface Loopback20
ip address 10.51.5.5 255.255.255.255
ip pim sparse-mode
interface GigabitEthernet0/15
description WAN
port-type nni
description IPTV-LAN
port-type nni
switchport access vlan 302
interface Vlan301
ip address 10.51.3.17 255.255.255.240
ip pim sparse-mode
interface Vlan302
ip address 10.17.1.7 255.255.255.0
ip pim neighbor-filter 5
ip pim sparse-mode
ip route vrf IPTV 10.51.4.0 255.255.255.0 10.51.3.30
ip sla enable reaction-alerts
access-list 5 deny any
R1#sh ip pim vrf IPTV rp mapping
RP: 10.51.5.5 (?)
R1#sh ip mroute vrf IPTV
(*, 239.1.1.141), 01:15:01/00:02:57, RP 10.51.5.5, flags: SJC
Incoming interface: Null, RPF nbr 0.0.0.0
Vlan301, Forward/Sparse, 01:14:20/00:03:05
Vlan302, Forward/Sparse, 01:15:01/00:02:57
(*, 239.1.1.140), 01:15:01/00:02:03, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:01/00:02:03
(*, 239.1.1.143), 01:15:00/00:02:57, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:00/00:02:57
(*, 239.1.1.142), 01:15:01/00:02:01, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:01/00:02:01
(*, 239.1.1.102), 01:15:00/00:02:57, RP 10.51.5.5, flags: SJC
Vlan301, Forward/Sparse, 01:14:22/00:02:51
(*, 239.1.1.101), 01:15:04/00:02:58, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:04/00:02:58
(*, 239.1.1.100), 01:15:07/00:02:54, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:07/00:02:54
(*, 239.1.1.99), 01:15:01/00:02:57, RP 10.51.5.5, flags: SJC
(*, 239.1.1.98), 01:15:07/00:02:55, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:08/00:02:55
(*, 239.1.1.111), 01:15:08/00:02:57, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:08/00:02:57
(*, 239.1.1.110), 01:15:00/00:02:57, RP 10.51.5.5, flags: SJC
(*, 239.1.1.109), 01:15:06/00:02:56, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:06/00:02:56
(*, 239.1.1.106), 01:15:05/00:02:51, RP 10.51.5.5, flags: SJC
Vlan302, Forward/Sparse, 01:15:05/00:02:51
--More--
