Community Member
Ping Local Interface Not Successful?
I'm on the local router and CAN NOT ping my serial interface serial5/0 (10.0.6.254). I can ping ever other physical interface without issues.
When I do a show ip route for 10.0.6.254, it says that it's connected to G0/2. It should say directly connected S5/0. I just recently upgrade the code on the router to 12.4, but don't think that's the problem. Attached is the ping results and the router configuration. Any assistance would be appreciated. Thanks.
Re: Ping Local Interface Not Successful?
David,
You are learning 10.0.6.252/30 from ospf and se5/0 is configured with a /24, hence the ospf route via g0/2 being preferred. Change the mask on se5/0 to a /30 and it should solve the issue.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Community Member
Thanks. I don't know how I missed that. You da man!
120
